@Chellykel81 I can definitely help you out! I'd recommend the following:
1. Restart your Flex.
2. Reboot your iOS device.
3. Open your iOS settings > turn off Bluetooth for 10 seconds > and then turn Bluetooth back on.
4. Open the Fitbit App to initiate a sync.
This should get you back on track, but let me know if you need any additional assistance. Welcome to the Community!
Hi all
I have a new iPhone 5se, with the same blue tooth than iPhone 6s, and some times syncs and sometimes not...
Even if I turn off the BT, the APP or the phone and then restart, i have no sync... or I have sync, it depends on fortune.
Is there a trick to reset the BT on the tracker without loosing the data?
BTW my tracker is a Charge HR
Regards.
Hi @Gundisalvo,
Just a heads up, I've merged your post into this thread. The steps mentioned in my post above should also help you out!
Welcome to you as well!
Best AnswerHi @DerrickS.
Thanks for the welcome, the merge and for the solution; with your solution it works again!
Regards
@Chellykel81 It's great to hear that you're getting a new Fitbit now you're ready to get back on track 😄 in order to set it up take a look at this article.
@Gundisalvo now you're back on track take a look at our Discussions board? There you can share your story, find some fitness tips, recipes and more! Give it a look!
Catch you later!
