08-17-2016 12:27
08-17-2016 12:27
08-17-2016 13:26
08-17-2016 13:26
Hi @_hunt_17
Since having done everything possible,
Feel free to contact the Fitbit Support Team: India | United Kingdom | United States
Optionally check out Returns & Warranty before contacting support.
Mention what you've already tried to speed things up.
Best Answer08-17-2016 14:08
08-17-2016 14:08
@_hunt_17 Welcome ot the Fitbit Community! I think I can help you out.
Setup for Fitbit trackers is actually done within the Fitbit App, not your iOS Bluetooth settings. What I would recommend is that you use the replacement setup process mentioned here to re-pair your tracker to your account.
This should get you back on track, but let me know if there's anything else that I can do to help!
08-19-2016 12:10
08-19-2016 12:10
Best Answer08-19-2016 13:43
08-19-2016 13:43
@_hunt_17 If your Fitbit App is not showing the Alta (since it sounds like you removed it), you should be able to follow the replacement set up instructions as mentioned above.
Have you tried those steps? If so, what is happening or not happening? (Seeing any errors, etc?)
Let us know, and perhaps we can help further.
Kelly | Oklahoma
Alta HR, Blaze, Flex 2, Charge 2, Charge, and Aria * IPhone 7+
Best Answer08-19-2016 20:51
08-19-2016 20:51
Best Answer08-20-2016 05:25
08-20-2016 05:25
@_hunt_17 Glad to hear you got it resolved through customer service.
Kelly | Oklahoma
