03-04-2017
08:45
04:41
MarcoGFitbit
03-04-2017
08:45
04:41
MarcoGFitbit
I bought a new Flex and followed the steps given in the app, but couldn't connect it to my Iphone 7 and then i followed the other steps given in the forum such as reboot, reset and bluetooth on off. But still it cannot be connected to my phone. Any suggestions??
Best Answer03-06-2017 04:40
03-06-2017 04:40
Hello @Dhanuka, thanks for joining us, it's great to see new faces around the Community! ![]()
This seems like a very odd situation, are you getting an error message when trying to set up your tracker through the Fitbit app? If so, please reply to me with a screenshot of the error you're getting, that will help me investigate this further.
In the meantime, please restart your tracker once again and keep it plugged in and charging while trying to set it up as a new device once again:
If it's still not pairing, I would like to suggest checking @MarreFitbit's instructions about how to set up your tracker using a computer, these instructions have been very helpful for many members in the Community and I'm sure they will be helpful for you as well.
Give it a try and keep me posted in case you need anything else! ![]()
03-06-2017 04:40
03-06-2017 04:40
