11-12-2016 17:36
11-12-2016 17:36
11-13-2016 17:30 - edited 11-13-2016 17:30
@Flex2newbie You can go to your settings and choose mobile and/or email notifications. Here is the link for you:
https://www.fitbit.com/user/profile/notifications
Hope that helps~
Kelly | Oklahoma
Alta HR, Blaze, Flex 2, Charge 2, Charge, and Aria * IPhone 7+
Hope that helps~
Kelly | Oklahoma
11-14-2016 04:31
11-14-2016 04:31
Hello @Flex2newbie, have a warm welcome to the Fitbit family!
Were @Kmransom123's instructions helpful to you? If so, I would like to encourage you to accept it as a solution, that will let other member know your inquiry was resolved.
Keep me posted if you need anything else, happy stepping!
11-14-2016 15:33
11-14-2016 15:33
11-14-2016 15:34
11-14-2016 15:34
11-15-2016 03:07
11-15-2016 03:07
Excellent @Flex2newbie! Please keep me updated and let me know in case the notification is still not coming through.
Have some spare time? Then, please check our Discussions board where you will find other members sharing their experiences and tips for an active lifestyle. Happy stepping!
11-16-2016 04:22
11-16-2016 04:22
Thanks MarcoGFitbit, it worked a treat - I got a low battery notification this morning when I synced 🙂 Happy days
11-16-2016 05:19
11-16-2016 05:19
Awesome @Flex2newbie!, I'm very glad to hear the "low battery notification" is now coming through. Please, don't hesitate to reply if you need anything else!
See you around!
02-01-2017
08:16
05:04
MarcoGFitbit
02-01-2017
08:16
05:04
MarcoGFitbit
I have all notifications marked on my setting and am still not receiving any emails notifications for low battery life. Might as well not wear it if I am using if for a day or two without anything being recorded. I do not check it every minute to notice when it is low. When I had the Flex model I never had this problem and always received my email notifications. Can someone please provide some help or I might as well get rid of the item and not frustrate myself any longer.
Moderator Edit: Format.
08-22-2017
08:37
05:05
MarcoGFitbit
08-22-2017
08:37
05:05
MarcoGFitbit
Same here. I'm getting no low battery notifications on my Flex 2, yet I have both mobile & email checked. Please help!
08-23-2017 05:37 - edited 04-17-2018 04:32
Hello @Jrow and @Dmadassa, thanks for joining the conversation, have a warm welcome to the Fitbit Community.
If you're not receiving battery notifications via email or phone, I would like to suggest you to reset these notifications by disabling them from the Notifications settings on the online Dashboard. Then, save the settings, enable them back again and save one last time.
Please keep in mind that if your tracker has not synced and the battery is low you won't receive the notification until the tracker has been synced with the Fitbit app. Additionally, please make sure to check your spam folder in case any email from Fitbit has been redirected there and check that the following settings are enabled in your phone under Settings > Notifications > Fitbit:
I hope this can be helpful, give it a try and let me know the outcome.
08-23-2017 09:29
08-23-2017 09:29
I checked everything when I first set it up. I just unchecked the selections and re-checked. I've also restarted per the instructions. If the kinks aren't fixed soon, so they're not eating up so much of my time and causing me a lot of frustation I'm going to return it.
04-16-2018 18:15
04-16-2018 18:15
I found that I had turned off notifications on my iPhone for Fitbit and have now turned them back on. Thank you for the post.
04-17-2018 04:36
04-17-2018 04:36
Hello @NickRP, have a warm welcome to the Fitbit Community, it's great to have you on board.
Thanks for taking the time to let me know your issue has now been resolved by turning off the Notifications on your iPhone, I'm very glad.
In case you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
04-24-2018 05:54
04-24-2018 05:54
Hi Marco,
I noticed last evening on my iphone app that battery was red and decided to wait for a notification on my phone or an email. Since then my silent alarm did work this morning nor were any steps recorded during the night. I did receive an email this morning at 6:54 and never did receive a notification on my iphone. Please help get the notifications to work and the email to send earlier in the battery drain cycle.
Thank you,
Nick
04-25-2018 05:00
04-25-2018 05:00
Hello @NickRP, I hope you're doing well, thanks for taking the time to reply.
I appreciate you have shared your experience with me, did you sync your tracker the night when the battery was red? Please note that unless the tracker gets synced, the app will not now the exact battery level of the tracker, which might prevent you from receiving the battery level email and notification at the correct time.
If your tracker got synced but you're still not getting the battery level notification via email or through your phone, please go to the Notifications Settings on the online Dashboard. In here, un-check the boxes for Low Battery and click on SAVE, then check them back and SAVE again for the changes to apply. After that, monitor the tracker and let me know if you're still experiencing this issue.
10-31-2018 19:02
10-31-2018 19:02
11-01-2018 08:28
11-01-2018 08:28
Hello @jwlarkins59, thanks for joining the conversation, it's a pleasure for me to welcome you to the Fitbit Community.
I appreciate your participation in the Forums and for sharing your experience with us. I would like to thank you for having tried the troubleshooting steps provided on this thread. If you're still unable to see battery notifications on your phone, and you already have "All-day Sync" enabled, I would like to suggest you to set up your Fitbit device as a new device to reset the connection between the device and your phone, improving the notifications. Don't worry, none of the information already stored in your account will be deleted.
To set up your device as a new device:
I hope this can be helpful, if there's anything else I can do for you, please feel free to reply.
11-06-2018 15:50
11-06-2018 15:50
11-07-2018 06:30
11-07-2018 06:30
Hello @jwlarkins59, I hope you're doing well, thanks for taking the time to reply and let me know your issue seems to be resolved, I'm very glad!
