11-12-2016 17:36
11-12-2016 17:36
08-27-2020 19:18
08-27-2020 19:18
It would be so much easier for the watch to tell me the battery is low than search for an email
11-01-2020 00:19
11-01-2020 00:19
I went to my profile/notifications and both my email and my text were already checked, but I have not been getting the warnings. I unchecked them and then re-checked them. Then I found one answer that said to uncheck them and Save and then check them and Save. So I just did that. I won't know if that worked until my battery gets low again.
Thank you!
Best Answer11-25-2020 16:41
11-25-2020 16:41
Doesn't work. Tried that a few times
Best Answer07-23-2021 21:53
07-23-2021 21:53
Doesn't work. Never did. Any other suggestions?
08-27-2021 16:31
08-27-2021 16:31
Thanks! For the quick response.
