My Fitbit will not connect anymore through Power Sync to Apple Health
Why won’t my Fitbit connect thru power sync anymore to apple health anymore. Have not had this issue before.
Moderator Edit: Formatting.
12 REPLIES 12
Hello @Jaxman7
I moved your post from the Charge 6 product help forum to the iOS platform forum where you are more likely to get help from other iOS users.
Having the same problem, stopped syncing on August 12, 2025.  I wonder if its the new Google/Fit bit account blocking access.
Might be. Mine quit the same day!
Thank you
I am also having issues with PowerSynv on my iPhone (latest iOS update), latest version of FitBit and PowerSync - mine is crashing each time I run is and then annually sync. Am not sure if automatically sync is working or not. I am also when I try Sync Solver (but with that one I can partially sync. - see attachment for error message).
’m experiencing the same issues. I’ve tried every solution possible, but nothing seems to be working.
I’m having the same issue also
Same issue here
Is yours working now?
As of this morning the issue still remains. Thank you for asking.
Same here.
Same, How does fitbit not have a native app built to sync with Apple?
I am having this same issue and have done all the suggested fixes too. Nothing works. Mine also stopped syncing around 8/12
