05-31-2016 05:16
05-31-2016 05:16
I have got a new Fitbit Surge and want to replace my broken Fitbit Surge.
I am using an apple iphone and open the Fitbit App
click on accounts
click on + Set up Device
Choose Surge
Click on 'Replace your Fitbit Surge'
and it has an icon flashing with 'Loading' but seems to be just stuck here... Have waited a few mins now with no change.
How can i fix this issue?
Thank you
05-31-2016 11:01
05-31-2016 11:01
@pej Welcome! I can definitely help you out, I'd recommend:
1. Open your iOS settings > open your Bluetooth settings > and if there is a Bluetooth bond between your iOS device and old Surge, forge the device.
3. Rebooting your iOS device.
4. Open your iOS Bluetooth settings one more time > turn off Bluetooth for 10 seconds > and then turn Bluetooth back on.
5. Use the replacement setup instructions listed here to pair your replacement Surge to your Fitbit account.
6. If for some reason steps 1-5 are ineffective, you can also use the replacement instructions hyperlinked in point 5 to pair your Surge using either a computer or a different mobile device.
This should get your new Surge all set up, but let me know if you need any additional assistance.
Best Answer06-02-2016 08:22
06-02-2016 08:22
I have exactly the same issue as PEJ but the instructions you gave didn't help. I'm also stuck with it trying to load new surge and I did disconnect damaged fitbit surge....Any other suggestions?
Best Answer06-14-2016 18:03
06-14-2016 18:03
I am also experiencing the problem and need to replace the device quickly. None of the instructions have helped to this point
Best Answer06-27-2016 10:25
06-27-2016 10:25
I have exactly the same issue as PEJ but the instructions you gave didn't help. I'm also stuck with it trying to load new surge and I did disconnect damaged fitbit surge....What else can i do?
Best Answer07-02-2016 07:02
07-02-2016 07:02
And I am experiencing the same issue (stuck "Loading"); followed all the steps from above; nothing working. This is my second replacement Surge (3rd in all). Does anyone have any suggestions?
Best Answer07-03-2016 20:14
07-05-2016 12:37
07-05-2016 12:37
@infoage1985 @aubsterlobster There shouldn't be a setup issue with the App. I don't mean to be redundant, but the steps mentioned above should get you setup with a replacement tracker.
If for some reason you aren't able to set up your tracker using your iOS device; I would then recommend trying to setup your tracker on either a second mobile device or a computer.
Hope this helps you both out!
Best Answer08-02-2016 18:52
08-02-2016 18:52
I'm experiencing the same issue. These instructions are not helping.
Best Answer08-02-2016 19:21
08-02-2016 19:21
deleting and reinstalling the app solved the problem. I was able to set up the replacement after that.
