oh my God, I just found the solution. It is going to take me deleting my Fitbit app and starting all over from scratch, deleting my new map and starting all over from scratch and then hoping and praying that the two actually connect. That’s hours And lots of frustration. When I just contacted Noom and I have a simple solution. Update their step count manually from your Fitbit app. So much easier and here’s how you do it:
To enter your steps manually, please do the following:
1.Set your step source under Settings > Apps & Devices to System Pedometer.
2. Adjust your steps manually by tapping your Walk XXX Steps task on the Noom home screen.
3. Tap the 3 dots in the top right corner.
4. Tap Adjust Step Count.
5. Enter the number of steps.
6. Tap Save.
