05-06-2016 14:58
05-06-2016 14:58
I have an ipad mini vers 9.3.1 The app was on there but then I took it off due to technical problems. Now when I go back into the app store I can not find the app. It does not come up.
I also have an old iphone 4 with ios 7.3.1 That ios is too old for the fitbit HR.
I have an HPlaptop and on this website can't find any way to update or sync.
So I quit wearing it. The time on the watch lags real time by 2 1/2 hours. It use to be correct. Not sure why that happened. It just seems to be more troublesome than worth it. I rather just run and walk without all this nonsense.
Planning to locate receipt and return it.
05-06-2016 16:50
05-06-2016 16:50
@Debilee823 There is not an app for the IPad - you have to download and use the one for the IPhone. In the App Store, change to "IPhone" apps, and you will see it.
Kelly | Oklahoma
Alta HR, Blaze, Flex 2, Charge 2, Charge, and Aria * IPhone 7+
Best Answer05-12-2016 09:21 - edited 05-12-2016 09:22
Welcome to the Fitbit Community @Debilee823, hope you're doing great today! My friend @Kmransom123 is totally right, when searching for the Fitbit app in the App Store, select "iPhone only" from the top navigation. Otherwise, the Fitbit app will not appear in search results.
Were you able to set up your buddy? Have you checked that your iPad is listed in the supported devices?
See you both around!
