03-31-2017 00:46
03-31-2017 00:46
I'm trying to do same thing on Charge2 - I only have a + sign to add to the preset goal of 1893 MLS. No gear icon in Water menu.
Best Answer04-04-2017 09:44
04-04-2017 09:44
Hello @JulieU01, thanks for joining us, it's great to have you on board! It's nice to see you around too @Rich_Laue, thanks for your insight in this situation. ![]()
@JulieU01, in order to change your water intake goal, first tap on the Account button at the top right corner of the screen.
Then, tap on Nutrition & Body
Finally, you can change your water goal by tapping on the current goal, then delete the amount shown and type your new goal.
To save your new goal, tap on the [< Account]
I hope this can be helpful, give it a try and keep me posted in case you need anything else! ![]()
Best Answer03-31-2017 00:47
03-31-2017 00:47
I should have said - through the App.
Best Answer03-31-2017 00:57
03-31-2017 00:57
And I'll ask which phone or is it a win10 computer
Best Answer03-31-2017 01:17
03-31-2017 01:17
Hi Rich in NJ - from Edinburgh
its a iPhone 6S Plus.
Thank you!
Best Answer03-31-2017 11:50
03-31-2017 11:50
While I don't know a thing about ios on Android you click on the gear in the top right, then type in the new goal.
This can also be done through the web by clicking on the water tile and clicking the settings gear.
04-04-2017 09:44
