06-22-2016 08:19 - edited 06-22-2016 09:18
I just recieved my replacement HR in the mail, but my bluetooth on my Iphone 6s will not recognize the new tracker and when i go into the fitbit app, account, set up device, then choose the option to switch to a new device i click on the replace fitbit HR but it never recognizes my new one it just continues to load for forever.
Best Answer06-22-2016 15:03
06-22-2016 15:03
Hi @Tess_Schumacher, I think I can help you out! I would recommend the following steps:
1. Restart your new Charge HR.
2. Reboot your iOS device.
3. Open your iOS settings > turn off Bluetooth for 10 seconds > and then turn Bluetooth back on.
4. Use the replacement setup process to pair your new Charge HR to your existing Fitbit account.
You don't have to remove the Charge HR from your account, doing the replacement setup process will ask you if you want to replace your current tracker.
Please keep me posted if this helps!
Best Answer06-22-2016 08:53
06-22-2016 08:53
Do i have to remove my old charge HR from the app where it says "Remove this Charge HR" first before my new one can be recognized? or will that lose all of my data?
06-22-2016 15:03
Best Answer06-23-2016 08:26
06-23-2016 08:26
Got it up and working! Thanks so much! 🙂
Best Answer06-24-2016 22:23
06-24-2016 22:23
I have the same issue as Tess but unfortunately I've tried the steps you provided a couple of times now and it didn't fix the problem. Any other suggestions?
@DerrickFitbit wrote:Hi @Tess_Schumacher, I think I can help you out! I would recommend the following steps:
1. Restart your new Charge HR.2. Reboot your iOS device.
Best Answer06-25-2016 16:58
06-25-2016 16:58
Issue solved by deleting fitbit app on my phone and re-installing it. I was able to add replacement tracker within 5 minutes after that!
07-01-2016 20:22
07-01-2016 20:22
Best Answer07-10-2016 16:45
07-10-2016 16:45
Best Answer07-10-2016 16:59
07-10-2016 16:59
Best Answer07-10-2016 17:22
07-10-2016 17:22
Hey!
I followed all the steps from the first post and it started the set up but I am still getting an error message. I deleted the app and reinstalled it but that did not help. Any other ideas?
Best Answer07-20-2016 23:13
07-20-2016 23:13
thanks for your help
08-02-2016 19:18
08-02-2016 19:18
Thank you Linda.
Best Answer08-06-2016 07:47
08-06-2016 07:47
Hello @leigh.santy, hope you're doing great today! If you've tried what @DerrickS has provided in this post, but you're still getting the error I'd recommend getting in touch with Fitbit Support directly so they can give you a hand on this.
Don't forget to mention the steps you've done so far to avoid getting the same ones, I'm pretty sure they will find where the issue is coming from.
Don't lose the hope yet, have a good one!
