Best AnswerHello and welcome to the Fitbit Community @Kellbell78
I can see from your post that your very frustrated. I understand that and I’d like an opportunity to help you if possible. Currently notifications is a know issue and the Fitbit Team is indeed working on trying to get a fix out. I have no timetable on when that will happen but you can keep an eye out on the updates on the notification (calls/text) issue here: https://community.fitbit.com/t5/iOS-App/Stopped-seeing-notifications-after-updating-to-iOS-13/td-p/3...
I can share with you my understanding of some tips that may help with your notifications issue but again there are no promises I can make and if these tips I share indeed get your notifications to work they will only do so with notifications previews.
Tips to try and get your notifications to work:
Tap your profile picture in upper left
scroll down to the name of your Fitbit and tap it (It’s located just under “My Family”
scroll down and tap notifications
enable the notifications you want in green
now simply tap “today” at the bottom of your screen to get back to the main page
Now lets make sure your iOS device is set up correctly:
go to:
device>settings>location services >Fitbit> select Always
also Go to:
device setting>Fitbit>Location>select Always
also go to:
device settings >notifications >messages>Select always under show previews
now go to your Bluetooth settings and look for your Fitbit Tracker and see if there is a small letter “ i “ with a circle around it. If there is tap that little “ i “ and select Shared notifications and enable it.
If would also suggest restarting your Fitbit Tracker to see if that helps your steps that you don’t feel are being logged properly. You can see how to restart your Fitbit tracker here: (you might benefit by trying the restarting processes a few times) : https://help.fitbit.com/articles/en_US/Help_article/1186
If Ayer doing all this you still don’t feel your Fitbit App is not tracking correctly I would suggest deleting the Fitbit App completely and then reinstalling. You will not lose any data doing this.
Here’s how:
1. Log out of the Fitbit app and force shut the app by swiping up
2. uninstall the Fitbit App from your device
3. now completely shut down your device and wait about 1 min then restart your device
4. once your device has reloaded reinstall the Fitbit app by downloading it from the App Store
5. once it’s installed, log into your device as you normally would with username and password
6. don’t touch anything in the app...just wait until you get a prompt from your Bluetooth.
7. When prompted by your Bluetooth tap yes
8. now sync your tracker
😃 I do hope my suggestions do indeed help resolve your issues. Please keep me posted on its status. I also wish you the best of luck in your up and coming marathon.
