02-15-2016 13:19
02-15-2016 13:19
Best Answer02-16-2016 05:10
02-16-2016 05:10
@Kimneal22 A warm welcome to the Community! Please make sure that you're doing this procedure to set your water goal.
It seems that you're writing from your iPhone so follow these steps:
Go to the app > tap on Account > Tap on Nutrition & Body > When seeing water, enter 60 so it will be your goal.
Also, check that you have oz set as your unit. To do so, go to the app > tap on account > scroll down and you're going to see settings > tap on advanced settings > tap on units > choose Fluid Ounces (oz).
Hope this helps. Keep me posted.
P.S. I moved your post to the iOS app.
