Can you keep the water from changing back to ml after it's been switched to ounces? I like to calculate it in ounces. Then it switches back to ml & the calculations don't appear correct.
You need to log into fitbit.com from your pc. In the upper left corner you will see settings "gear" icon. Choose that and you will find the option to change MIL to OZ. Hope this helps.
