02-25-2017
06:24
06:56
RobertoME
02-25-2017
06:24
06:56
RobertoME
Hi, I set my weight loss goal on Jan 1st this year, and then tried to edit my target the following day, but then it reset the start date to the 2nd instead. This throws off my figures, because my weight was higher on the First. I'm using the iOS app and can't see any way to choose the start date of the goal without it getting reset to the current day. Is there any way to do that (does the web interface let you do that)? And if not, I'd like to add "edit starting date" as a feature request.
Moderator Edit: Updated Subject For Clarity.
Best Answer02-28-2017 06:52
02-28-2017 06:52
Hello @womandrogyne, good to see you keep participating in our Community boards. Note this happen when you edit your weight goal. The reason of this is because you are entering a new starting weight with the last weight entry you have. So for the app at this point it wont recognized you have lost any weight.
In order to return to the way it was, you need to enter on your starting weight, the same initial weight you had. You can do this from your Account Tab > Look for the "Nutrition & Body" option > In starting weight change back to the first entry you had.
Hope this helps. Keep me posted if you need anything else.
