03-27-2024 08:06 - last edited on 03-27-2024 13:41 by ManuFitbit
Is there a way to adjust the visibility of the display?
Moderator edit: clarified subject.
03-27-2024 13:26
03-27-2024 13:26
Welcome to the community forums @dabl79.
Thank you for taking the time to share the inquiry regarding your Inspire 2.
Please restart your Inspire 2 as suggested here How do I restart my Fitbit device? If the restart doesn't work, please try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
If none of the above works, please check if by any chance your Inspire 2 is in sleep mode. When the sleep mode setting is on:
Notifications and reminders are muted.
For more information, see How do I navigate my Fitbit device?
03-31-2024 08:07
03-31-2024 08:07
What clock faces are best to help see screen better? I've already rebooted and gone into settings to check and turn off dim and then rebooted again with no improvement.....?
04-06-2024 06:17
04-06-2024 06:17
I don’t even see an option on my Inspire 2 for clock face options. Is this available only in premium?
04-07-2024 01:23
04-07-2024 01:23
I'm reposting THE SAME THING that I posted on here.
This does not work.
I own two Fitbit Inspire 2 and one of them has the screen so dim that I can't even see indoors. I have to be in a very pitch black room to see the screen. I have contacted warranty and they say that warranty does not apply for this issue. This is a manufacturing issue that should be covered by Fitbit/Google, but no.
Fitbit fix this stuff.
04-09-2024 10:39
04-09-2024 10:39
I have had this problem for at least a year. This is a design fault, the Fitbit suggestions don't work.
04-13-2024 15:58
04-13-2024 15:58
None of the clock faces have fixed the issue for mine, but I tried several and the Valerie clock face was the better of the few I tried. I had to do this in a dim room to even be able to see the screen.
04-22-2024 05:56
04-22-2024 05:56
Hi AN-G
I am replying to this post again: I replied previously and it was taken down... see this message... very poor reaction on behalf of FITBIT. The post was on topic in my opinion...
Hi there,
I wanted to let you know that I've removed one of your recent posts (quoted below), as it was off-topic and not contributing to the conversation.
Thanks for the advice, I did try but no improvement. I think this is a major problem with this device but Fitbit has prevaricated over ways to fix it, repeatedly advising methods that don’t work… I think people must just give up and move onto a different device.
04-22-2024 06:01
04-22-2024 06:01
Hi
Hi have replied in this thread and FITBIT removed my post... too critical of the company obviously
04-22-2024 22:28
04-22-2024 22:28
I am also experiencing this issue, and it frustrates me to no end. I don’t know what the life expectancy is for an Inspire2. Mine is 3 years old. I can see the screen if I’m indoors but not at all if I’m outside.
04-23-2024 01:40
04-23-2024 01:40
I cannot see my screen inside though, so can only adjust when in total darkness 😠
04-23-2024 06:00
04-23-2024 06:00
Mine is not visible at all..... ever. I give up and just see what I can see on the app. However, this will be my last fitbit.
