04-28-2024 22:08 - last edited on 04-29-2024 08:55 by MarreFitbit
I have tried all of the recommendations... I have uninstalled and then reinstalled the app. It works for a few days and then stops synching again. I uninstalled the app again and reinstalled again today. I went through all of the steps to apply the appropriate settings like I usually do but today the app won't synch. All of the started happening about 2 weeks ago after the update.
04-30-2024 08:21
04-30-2024 08:21
Hi there, @Kindrathrasher. It's nice to see you around the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Inspire 2 is still not syncing properly. I understand where your concern is coming from, I will do my best to help you with this!
To better assist you, would you mind confirming whether you've tried all tips and recommendations provided here Why won't my Fitbit device sync?
If that was already attempted but to no avail, please try the following steps in the order listed:
With the steps above, what I want you to do is to pair your Inspire 2 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
05-06-2024 10:05
05-06-2024 10:05
Hello. I completely all of the steps you recommended. I got it to synch again. It worked for a week and then stopped again. I then disconnected and reconnected it to Bluetooth to get it to synch again. I hope the developers are working on a solution to this problem. This should not be happening so often.
05-07-2024 16:07
05-07-2024 16:07
I am having the same problem and have also completed all of the steps you noted above multiple times, including removing all other Bluetooth devices which is going to be inconvenient when I need to connect those up again. My Inspire 2 still will not connect with the Fitbit app.
05-12-2024 04:37
05-12-2024 04:37
Hi, I have happily worn my Inspire2 Lunar since I bought it in August 2021. however the other day it started vibrating madly and I lost the steps, miles and pulse (the things I do look at) on my fitbit. Every time I try to sync the fitbit with my android phone I get a message telling me:- "There was an error while trying to bluetooth pair your device". I have assumed this is the way back to getting my fitbit working?
I have wondered if at nearly 3 years old the fitbit has just backed up? The battery doesn't last as long as it did but it still lasts for several days.
Is there any advice you can give me. I'm not very good with techy things. Get confused easily!
Thank you
