02-08-2024 17:35
02-08-2024 17:35
The screen light keeps coming on on my Inspire2. This is happening without moving or touching it. I have restarted the device. The light continues to come on while it is charging. It will light up for about 5 seconds, flash off then come right back on. It is draining my battery within hours and it is impossible to sleep with it on when the light keeps flashing. I appreciate any help! Thank you!
02-09-2024 07:31
02-09-2024 07:31
Hi @Danielle2115. Welcome to the community forums.
Thank you for taking the time to share the inquiry regarding your Inspire 2. Sorry to know the difficulty.
Please make sure you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
If the above doesn't work and since your Inspire 2 keeps flashing the Fitbit logo, please try the following:
02-13-2024 16:24
02-13-2024 16:24
Thank you for the assistance. Unfortunately, those options did not solve the issue. I restarted the device. I attempted to change the clock face. The new face download could not be completed. I attempted to change back to the old clock face and even a completely different one and it says that the application did not finish installing, do I want to continue installing. The install will say it cannot be completed so that is also the screen that I am currently stuck with in my Fitbit. It is also not the Fitbit logo that was flashing but the clock face itself. Basically the clock light flashes off for a second or two and it otherwise lit- which obviously drains the battery very quickly.
