03-25-2023 16:13
03-25-2023 16:13
I purchased my Sense and after 7 months the stair count went wonky counting WAY too many stairs. After multiple fix attempts Fitbit replaced the device. Worked great for another 8 months then BAM same issue. Fitbit stated that it was out of warranty. Escalated, but doubt I will get a resolution. As a US customer, now I see why the EU pushed for and has a 2 YEAR warranty. Can Fitbit explain why they won't warranty the replacement device as if it were new?!? Not my fault the original device AND the replacement device failed within a year!!! UGH!
03-25-2023 17:29
03-25-2023 17:29
I am not Fitbit, but in the Fitbit Limited Warranty , it is clear that it is from the date of purchase. I can understand that you might think it should be from the date of receiving a replacement, but that is not what the warranty states.
03-26-2023 19:03 - edited 03-26-2023 19:04
True. However, having the same problem with the replacement device in a similar 7-8 month period does little to instill confidence that one of the key components of this watch - stair count is a reliable feature. Further, European Union customers have a two (2) year warranty period, you'd think that as an American company it would match this; corporate greed, or does the EU have better consumer protections?
Fortunately, I purchased this through Best Buy and as a Total Tech Member I have a two (2) year warranty under them, and was provided with a replacement. Should this THIRD Sense device have the same step count issue within 7-8 months, rest assured I will look at Fitbit's competitors for Droid users - Samsung, Google, or Garmin.....
