Hello,
My son has been using the ACE 3 and it is tracking sleep well but I am unable to figure out how his sleep last night is calculating?
It says he slept from 6:58pm to 6:58am. That is 12 hours total.
Now he was restless for 2hrs 42min and awake 8min
But it's showing his sleep total is only 5hrs 55min.
How is this calculated?
I assumed you subtract the total time restless and awake from the total time slept but that equals 9hrs 30mins I believe. How does it get to less than 6hrs?
Thank you!
Welcome to the Fitbit Community, @LauraM611.
Thank you for trying to get them resolved before contacting us. I appreciate your feedback regarding this experience, was this the first time you noticed this? Could you please share a screenshot of the sleep log you are referencing to? So we can take a better look at the information you mentioned earlier.
I recommend these steps that are helpful with app related issues:
- Force quit your Fitbit App
- Reboot your phone
- Restart your tracker, check this article to see how to do it.
- Force a manual sync on the App
-Try using it for another night and verify the data.
Hope this helps.
