05-22-2024
05:25
07:36
ManuFitbit
05-22-2024
05:25
07:36
ManuFitbit
Hi, My son's ace2 has stopped charging. I tried to clean up all points, USB slot including but no luck. It continues to not wake up and screen remains blank. No luck with rebooting either. can you please help.
Moderator edit: clarified subject.
Hi @HinaJ. Welcome to the community forums.
Thank you for sharing the inquiry about this difficulty with the Ace 2 and for trying to fix it on your own.
If it is regarding to a battery issue, please see the points listed in this help article.
In addition, please try to change the clock face asi indicated:
Tap Select to add the clock face to Ace 2 and sync the tracker.
Try to restart the device folling these points:
