10-22-2020 14:16
10-22-2020 14:16
We purchased an Ace 2 for my Daughter in early September. I have tried all the recommendations regarding charging and resetting, with no luck. I am able to reset the fitbit while plugged in, however, as soon as I remove the unit from the charger it shuts off. It is only recognized on the app dashboard while plugged in.
How do I get a replacement, as all efforts mentioned on here for corrective actions appear to not be working for anyone.
Thanks...
10-25-2020 06:35
10-25-2020 06:35
A couple things to try first:
1) restart the device several times in a row (like 3-4 times). That often fixes the issues we have had with the Ace.
2) try changing the clock face:
If neither of those work, then you should contact Customer Service to troubleshoot further.
