08-16-2019
00:07
06:15
JuanJoFitbit
08-16-2019
00:07
06:15
JuanJoFitbit
Charged daughter Fitbit ace overnight. It now just has an empty battery icon on the screen and can’t do anything with it. When I connect the charger it does vibrate. Have tried all troubleshooting?
08-16-2019
08:24
09:05
08-16-2019
08:24
09:05
Hi, @Mary10 , what have you been using to charge your daughter’s Ace? Remember that if yu are using a computer, in most cases it will not deliver charge unless it is awake and active. It is okay to use a wall charger as long as it is UL/CE certified. The original charger that came with your cell phone is ideal, as long as it will accept a usb cable.
You might also want to try cleaning the contacts and pins. Here’s how:
After that I would rcommend charging with a wall charger as recommended above, for 2 hours, even if it does not seem to be charging.
Once it has had 2 hours charging with clean contacts and pins, please try giving the Ace a restart: Press the button on the charging cable 3 times within 8 seconds, briefly pausing between presses. The button is on the end of the charging cable that is plugged into the computer. 8 seconds after the first button press, the Fitbit logo appears on the tracker's display. This indicates that Ace restarted.
If nothing happens, it’s worth repeating the rstart procedure 2 or 3 times more.
If that still doesn’t work, please post again and someone will be able to help you with the next steps.
@Mary10 welcome to our Fitbit Community! By the way, I'm sorry for the late response. However, regarding the battery issues that your daughter's Fitbit Ace is experiencing, I would like to follow up and would like to know if the issue persists or if it got resolved after following the great troubleshooting steps that shared my friend @Julia_G.
If you found her post helpful, please accept it as a solution so other users that experience the same issue can find it easier.
I appreciate the time spent trying the troubleshooting steps before contacting our forums.
Looking forward to your response! ![]()
