Fitbit Ace battery draining fast
ANSWERED
Hi. My Fitbit ace battery will only last a day and a half if we are lucky. It goes on charge all night. A day and half later it’s dead and needs re charging. I’ve turned off auto sync there are no alarms sets. I’ve cleaned the back in case there is dirt in it. I’ve also tried different USB ports. Any ideas? It’s still in its warranty we brought it from Argos as a Xmas present.
Moderator edit: format
1 BEST ANSWER
Accepted Solutions
Hiya,
My daughter got her Fit Bit Ace from Argos as a birthday present this month. Her best friend has a Fit Bit Ace and only has to charge it every 5 days.
Since the very beginning we are only getting about 48 hours out of it, before it needs to be charged again. There was a full battery at 9am on Thursday morning, needed to be charged again on Saturday and again on Monday and so on.
I have been following the forum over the last week and see that a number of people have similar issues and that there are a number of work arounds.
So we have tried the following:
* Turn off Auto Sync - It’s Turned off already
* No Alarms Set
* Cleaned the back in case there was Dirt in it
* Tried different USB Ports
* Cleaned the pins and lined up exactly to create a strong connection between the device and the charger
It is very disappointing that this should be happening and my daughter is definitely not at all impressed.
Obviously the product is within warranty as we bought it this month, March. So can you tell me what’s the next step?
Thanks for your help
21 REPLIES 21
@Emmaandtom1 It should definitely last longer than that. Have you tried restarting it?  Also, the charging cable can be a little sensitive - are you sure it is getting fully charged?
To restart: Press the button on the charging cable 3 times within 8 seconds, briefly pausing between presses. The button is on the end of the charging cable that is plugged into the computer. 8 seconds after the first button press, the logo appears on the tracker's display.
@Emmaandtom1 Welcome to our Fitbit Community! I'm sorry for the late response. Thank you by the way for troubleshooting this issue before contacting our forums.
I want to follow up and would to know if the issue persists  or if your Ace is charging properly now after following the great troubleshooting steps that shared my friend @Jrdubyakc.
Looking forward to your response! Smiley Happy
JuanJo | Community Moderator
Running with music makes you happy! Share Your Story
Hi. Nope was fully charged Saturday and by Monday it needed charging again. I’ve tried the reset by no joy 😢
@Emmaandtom1  Thank you for getting back! and trying the troubleshooting steps listed above. Since the issue persists, let me go ahead and forward your case to our Support team so they can investigate further and provide a solution. You will receive an email from them soon.
Let me know if you have any doubts! Smiley Happy
This just started happening with my Fitbit Ace too! I had it charge all night put it in at 610 AM and it was dead at 730 AM. I went home at lunch charged it up said it was a full battery at 400 PM and here it is 419 PM and it is DEAD!!!
@Alicia84 Thank you for participating in our Fitbit Community! I'm sorry to hear that your Fitbit Ace is unresponsive. even though you have charged it completely. Please try restarting your tracker as described in this help article. After this, check out if the issue gets fixed.
Keep me posted on the outcome! Smiley Happy
My daughters Ace is just 4 months old a d is having the same issue.  We have tried the resetting steps but the it foesnt even fully charge ...ever!!!
Best way I got mine to work was plugging into a computer each night. It
sucks but it's the only way I've found to work.
@sarahscooby Welcome aboard to our forums! I'm sorry for the late response. However, I'm sorry to hear that your daughter's Ace is not holding its charge as long as it should.
Please try cleaning the contacts of the Ace and the charger with a cotton swab and a little bit of alcohol in order to remove any dust that the contacts accumulate. Finally, charge the Ace for 2-3 hours and see if the battery lasts longer.
@Alicia84 I would like to follow up on the battery issues that your Ace is experiencing. Please monitor your tracker for 24 hours and let me know if the issue persists.
See you guys later! Smiley Happy
Hiya,
* No Alarms Set
I've found plugging into my computer has helped a lot. The batty will hold
a charge longer.
Otherwise take it back and get something better.
@Galway It's great to see you in our Fitbit Community! I'm sorry to hear that your daughter's Ace is not holding a charge as long as it should even though you have made sure of the details that may have the battery drained faster.
Due to this, I'll send your case to our Support team so they can investigate further and provide a solution. You will receive an email from them soon.
@Alicia84 Thank you for sharing your feedback. I'm glad to hear that your Ace is holding its charge longer.
I'll be around if you guys have any doubts! Smiley Happy
Same battery problem here. Battery goes from full to low in 45 min with no usage. Tried reset, turning off all settings in app, same problem persists. How can I get a replacement?
@IlCampionissimo Thank you for joining us in this thread and our Fitbit Community! I'll be happy to assist you with your Fitbit Ace since its battery is not lasting as long as it should. By the way, thank you for trying the recommended troubleshooting steps before contacting our forums.
Since the issue persists, I'll send your case to our Support team so they can investigate further and provide a solution. You will receive an email from them soon.
Let me know if you have any questions!Smiley Happy
That is exactly the issue my daughters Fitbit is having.  Customer service said.  Battery life is up to 5 days.  48 hours is adequate battery life.  So disappointed.  Avoid Fitbit ace like the plague.
@67bit, I'm sorry for the late response. I'm also sorry to hear that your daughter's Fitbit Ace is experiencing the same issue.
I would like to know if the tips that are listed in this help article were performed. If the issue persists, after trying these tips, let me know and I'll be glad to follow up and assist you accordingly.
Keep me posted.
We are having the same problem. My son received an Ace 2 for Christmas. We charge it fully overnight (battery registers at 100%) and by dinner (less than 24hrs later) it is dead. We have turned off continuous sync and alarms with no results. Very disappointed as we are long-time Fitbit users with many Fitbit products we love.
Hi @LauraB307, thank you for participating in our Fitbit forums. I'm sorry to hear that the battery of your son's Ace 2 is draining also, I'd like you to try the tips that are included in this help page in order to improve the battery life of the Ace 2.
After this, monitor your son's tracker and see if the issue gets fixed.
Let me know how it goes.
We just bought my daughter an Ace Fitbit for her birthday in July and are having the same battery issues. It will charge all night and then only last for a couple of hours. We have tried all of the above trouble shooting and still the battery life is poor.
