01-25-2024
02:03
14:24
LizzyFitbit
01-25-2024
02:03
14:24
LizzyFitbit
My 13 year old daughter would like a Fitbit, but the Ace is too childish. Which Fitbit could she use?
Moderator Edit: Clarified subject and updated label
Best Answer01-25-2024 02:54
01-25-2024 02:54
Hi, @EWnl , if your daughter is 13 she would be eligible for any of the grownup Fitbits. I would recommend either the Luxe or the Inspire 3. Both of them give all the basic information (heart rate, steps, distance, sleep analysis) and both are fairly delicate and pretty on a small wrist. You can get more information at the Fitbit shop - there’s a link at the top right hand side of every page here in the Community forums.
At the moment it looks like the Luxe is out of stock, except in the special addition which comes with a jewelry band, so the Inspire 3 with the basic silicone band may be the most appropriate.
I hope this helps - and your daughter enjoys her Fitbit whichever she chooses. Welcome to the forums!
01-25-2024 06:43
01-25-2024 06:43
@EWnl I moved your post to the Inspire 3 forum. It seems like a better fit for your question. I want to give you a head's up about a few things regarding Fitbit accounts and Google accounts.
What should I know about moving Fitbit to my Google account?
Laurie | Maryland
02-01-2024 01:10
02-01-2024 01:10
We are from the Netherlands, which makes it impossible to connect a Inspire to her phone beneath the age of 16. Family Link doesn't help. So we are stuck. Or she can use a Ace or she can't connect on a own device. It's a pitty there are no Fitbits for teenagers.
Best Answer02-01-2024 10:10
02-01-2024 10:10
Welcome to the Fitbit Community, @EWnl. I moved your post to the Ace and Family Accounts board and thank you for your feedback regarding Fitbit Ace being too childish for an adolescent.
I found two Product Feedback and you can vote for them, one is under consideration: Allow More Fitbit Devices than Ace to Family Account, Create a Fitbit device suitable for teens.
