03-13-2018
21:01
09:11
ErickFitbit
03-13-2018
21:01
09:11
ErickFitbit
Hi, l just wanna know Fitbit Ace is same with Alta? Same size? What can the kids do with it? It is said you can track sleep duration & sleep schedule, how to make it ? Thank you.
Moderator edit: edited title for clarity
Hi @Niclass, and welcome to the Community forums @aknbuffy, it's good to see you both around.
I can confirm the charging cable for Fitbit Ace and Fitbit Alta is the same, however, please note that the cable for Alta HR is different. Here you can find the charging cable and other accessories.
I hope this helps. ![]()
Bought my son the ace and my son is pretty thick his 9yrs old and I asked the guy if it would fit my son my son was there he said yes it’s all one size fits all but unfortunately it didn’t fit it was too tight for his wrist so Im reading in the comments the Alta will fit so I’m guessing I will go with a Large !
Hi @Jellybean1, it's great to see you around in the forums.
I'm sorry to see that happened with the Ace wristband being too tight, as you mentioned, Fitbit Alta and Fitbit Alta HR wristbands are compatible with Ace. The extra small wristband that comes with the Ace is shorter than Alta and Alta HR bands in size small. The Ace wristband fits wrists 5.0” - 6.34” in circumference.
I have also sent your information to the Customer Support team for further assistance with this, you should receive a reply soon.
I hope this helps.
Is the tracker part of the Ace the same size as the Alta? Are the bands the only difference in size?
Hello @lwmeche, welcome to the Fitbit family and the Community forums.
It's a good question, the pebble or tracker itself for Fitbit Ace is actually the same size as Fitbit Alta and Alta HR, it's about 3.5" in length. You can check the image in this post as a reference.
As you mentioned, the other difference in size would only be with the wristbands.
I hope this helps.
My 10 yo who is very slim with tiny wrists, has his Ace on the third hole comfortably. A bit loose, as recommended. I tried to post pic, but this website is not mobile friendly.
@Purplycat Welcome to our Fitbit Community! I'm glad to hear that your child's Ace wristband fits great. I also appreciate your feedback about the website. This helps us to keep improving our services.
@colombo13 That is correct! The info you described can also be verified in this page.
I'll be around if you guys have any doubts! ![]()
Best AnswerGood to know about the sizing of the Ace band. I have an Alta HR and the band is too large for my tiny 5 1/4" wrist. After a while the band stretches out resulting in my tracker not working properly.
Hello @phedder and @Jellybean1, it's great to see you around.
@phedder, it's a good thing that you found this information about the wristband sizes then.
Great @Jellybean1, thanks for sharing that information as well, I'm sure it will be useful for other users too.
Keep on stepping. ![]()
10-24-2018
05:54
08:12
JuanJoFitbit
10-24-2018
05:54
08:12
JuanJoFitbit
The two devices are the same physical size but the have different functions. The ace has a subset of the Alta’s functions. See the comparison charts on the Fitbit site for all the details.
Moderator edit: format
@FTutone Welcome to our Fitbit Community! Thank you so much for your contribution and feedback about the size of the Fitbit Alta and Ace.
I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
Hope to see you in our Fitbit Community! ![]()
