02-02-2024
12:46
11:44
ManuFitbit
02-02-2024
12:46
11:44
ManuFitbit
My Ace 2 watch does not sync properly with the iPad even though the timezone is right.
the timezone is Nuuk but the watch keeps sync two hours wrong +2 hours
please help
Moderator edit: clarified subject.
02-11-2024 14:50
02-11-2024 14:50
I would try the normal fix @Ixuscane. set for the wrong time zone, sync, set for the right timezone, sync. (the first sync may not be needed)
02-20-2024 11:24 - edited 02-20-2024 11:24
It's good to see you participating in the community @Ixuscane
Thank you for providing the details about this difficulty with your Ace 2. Sorry to know the difficulty experienced.
If in any case you still have issues with the time, please make sure to sync correctly. Here you will find the requirements to do it properly.
Thanks @Rich_Laue for your help.
