03-13-2018 21:01 - last edited on 03-15-2018 09:11 by ErickFitbit
Hi, l just wanna know Fitbit Ace is same with Alta? Same size? What can the kids do with it? It is said you can track sleep duration & sleep schedule, how to make it ? Thank you.
Moderator edit: edited title for clarity
03-13-2018 21:24
03-13-2018 21:24
I read its the same size as the alta. I assume its tracks steps, sleep. challenges, reminders to moves, goal.....everything the alta does. I also read that it took regular alta bands
03-13-2018 21:03
03-13-2018 21:03
Can Alta bands fit the Ace?
03-13-2018 21:24
03-13-2018 21:24
03-13-2018 23:19
03-13-2018 23:19
Is the band perfect and soft enough for kids?
03-14-2018 08:20
03-14-2018 08:20
If it takes Alta bands (as I assume it does based on the picture), the bands are pretty comfortable. I only have the Alta HR, which is interchangeable with the Alta bands as well. Mine is in the original band and it's quite comfortable.
one cruise ship at a time!03-14-2018 19:18
03-14-2018 19:18
thank you dear.
03-15-2018 15:59
03-15-2018 15:59
@AnnaZhang thanks for your question on Ace, @Bunnybear_05 and @DramaQueenDiva thanks for your assistance here look like you have it all covered.
@AnnaZhang for what it's worth, the Ace band is made of a flexible, durable elastomer material similar to that used in many sports watches, and includes an aluminum buckle. The same material we use for Alta and Charge 2.
Actively managing your weight? Find accountability buddies on the Manage Weight board
03-16-2018 19:34
03-16-2018 19:34
Isn’t the ace just the Alta renamed and marked to kids? It sure looks like one.
03-16-2018 20:28
03-16-2018 20:28
Yes it is. A smaller kids size band and a special app/account for it to satisfy the child privacy laws. And it’s s but cheaper then the Alta.
03-21-2018 10:00
03-21-2018 10:00
Thanks for all answers. Is it correct that the Ace band fits a Alta HR tracker?
03-21-2018 11:02 - edited 03-21-2018 11:06
Is there a plan to feature a leather band for the Ace?
It sounds like it’s the same size as the Alta so I’ll be able to order an Alta band but in my experience the off brand bands don’t stay clipped as well as the Fitbit brand ones do and the small Fitbit brand leather one is too big for him still.
My son has some sensory struggles and he won’t wear the sports band material...
03-21-2018 15:17
03-21-2018 15:17
@Niclass - Ace bands would fit the Alta HR tracker
@Starglowz - right now there are no plans to release a leather x-small band that I'm aware of. The closest Fitbit has is Alta HR bands in small which fit wrists 5.5" to 6.7"
03-23-2018 14:33
03-23-2018 14:33
@Niclasswrote:Thanks for all answers. Is it correct that the Ace band fits a Alta HR tracker?
Yes, any Alta or Alta HR band will fit the Ace.
one cruise ship at a time!04-28-2018 07:44
04-28-2018 07:44
Is the band that comes with the Ace smaller (measuring around the wrist) than the Alta? If so what size(s) of wrists does it fit?
04-28-2018 09:08
04-28-2018 09:08
I've heard that it is, but I don't know the exact measurements.
one cruise ship at a time!05-01-2018 12:15
05-01-2018 12:15
I have two custom sized bands for my alta HR purchased on Etsy.com. Fit for both my wrist and ankle. They are durable, comfortable and come in a variety of color schemes,
05-01-2018 14:24
05-01-2018 14:24
Amazon and EBay also have great alternatives for bands.
one cruise ship at a time!05-02-2018 12:29
05-02-2018 12:29
@heidijp Welcome to the Community boards, thanks for stopping by! The Ace band is sized x-small and measures 5.0" to 6.34"
07-16-2018 01:35
07-16-2018 01:35
Hi is the charger the same for the alta as the Ace
07-17-2018 00:22
07-17-2018 00:22
