10-31-2022
06:24
11:46
10-31-2022
06:24
11:46
My fitbit is starting to give me issues. Having trouble getting it to charge and seems to lose charge fast.
How old is your fitbit alta hr?
Hi there, @Rose413. Thanks for stopping by in the Community Forums and sharing the details about the issue with your Alta HR.
Please bear in mind that as with other electronic devices, the battery will depend on the features and how often they're used. While this doesn't mean that you shouldn't use them, please take into into consideration the conditions that impact your watch's battery.
That being said, I'd recommend to change the clock face to one designed by Fitbit and please confirm if you've followed the tips and recommendations to maximize your watch's battery life described here.
In addition, if your Fitbit device is not charging properly, please see Why isn't my Fitbit device's battery charging?
Hope that helps.
