11-28-2020
23:45
10:54
AlejandraFitbit
11-28-2020
23:45
10:54
AlejandraFitbit
Last week my Charge 3 screen went black although it still vibrates and tracks steps. I tried all the troubleshooting steps without success and after contacting customer service I was told that my Charge 3 is not under warranty so I pulled out my Alta HR (which was only replaced because I received the Charge 3 as a gift). I charged the Alta HR and followed the set up process on the app without problem, however a few hours later the screen on the Alta HR also went black! It seems to me that if the black screen is a consistent problem across multiple Fitbit devices then there must be a software issue. In case it matters, I am using the Galaxy S9 to sync devices.
I am really frustrated that I have had 2 Fitbit devices go from working perfectly to being completely useless in less than a week without any reason or user error. I am curious if anyone else has experienced similar issues. There's no way I'm buying a new Fitbit device just to have it join the graveyard of black screens.
12-24-2020
10:54
05:41
12-24-2020
10:54
05:41
It's great to see you around, @ToriB21.
I understand how are you feeling and appreciate all the efforts in trying to fix this display issue. Upon checking with our support team, I was told that you have already contacted them. I know they will be glad to help you out and provide you a solution, just keep an eye on your inbox for further assistance.
In the meantime, let me know if you need anything else.
