Alta HR blank display
Hi, my Alta HR is black and won't connect to the app. I tried to connect with the USB-port and push the button three times in four seconds and all that but it won't work. Is it broken or what to do?
Best regards
Karin
1 REPLY 1
Welcome to the Community, @SunsetRunner.
Thanks for troubleshooting this display issue. Upon checking with our support team, I was told that you have already contacted them. I know they will be glad to help you out and provide you a solution, just keep an eye on your inbox for further assistance.
In the meantime, let me know if you need anything else.
