01-08-2021
04:29
10:41
AlejandraFitbit
01-08-2021
04:29
10:41
AlejandraFitbit
Hi, I've had my Alta HR setup and working with my phone (Pixel 2) before but since I updated the Android system to version 11 it stopped syncing. Ive tried all the troubleshooting advice but with no success. The setting up gets to the point where I'm able to enter the 4-digit code from the device into the app it all fails.
I've even tried setting it up on my partner's phone which is identical to mine but still runs on Android 10 and it worked then. Can you please let me know what my options are?
Many thanks!
01-10-2021
10:42
08:37
01-10-2021
10:42
08:37
Welcome to the Forums, @YanNan.
Thanks for troubleshooting this setup issue. If you are having problems with this process, I recommend checking the article: Why can't I set up my Fitbit device? and make sure you have followed the steps there.
Let me know the outcome.
01-11-2021 01:58
01-11-2021 01:58
01-13-2021
10:05
08:36
01-13-2021
10:05
08:36
Thanks for getting back, @YanNan.
I've gone ahead and escalated your case to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
In the meantime, let me know if you need anything else.
