03-15-2016 14:51 - last edited on 08-20-2020 18:43 by MatthewFitbit
I got my Alta today and I've had it plugged in and charging for over 2 hours now and it won't turn on. If I tap the screen nothing happens, I've tried restarting it too. Any suggestions?
04-10-2017 04:29
04-10-2017 04:29
04-10-2017 04:44
04-10-2017 04:44
Plug your Fitbit in and press and hold the button on your charger until the screen on your Fitbit flashes with the Fitbit symbol or says welcome; depending on your device. If that doesn't work call 1-877-623-4997 and they'll troubleshoot it or replace it. Hope this helps!
04-10-2017 05:46
04-10-2017 05:46
Hi, @wovenweb, if you give some details of the problem you are experiencing someone can try to help.
04-14-2017 02:24
04-14-2017 02:24
My alto won't turn on . I hate it!!!
05-14-2017 11:36
05-14-2017 11:36
Charged, turned Blue tooth on and off. Phone does not recognise.....tapping does nothing but awaken the url address streaming across... ugh
05-14-2017 18:12
05-14-2017 18:12
This is exactly what's happening to me. Very frustrating
05-24-2017 10:38
05-24-2017 10:38
I have the same problem I have the exclamation mark with the circle and it won't turn on 😧 This is so frustrating I will never buy or recommend a Fitbit to anyone
05-24-2017 10:42
05-24-2017 10:42
05-28-2017 10:36
05-28-2017 10:36
I am exactly in the same situation I did everything you did and it is not my first fitbit I thought this will be so much better but I am so frustrated that I can't make it work. There is no site explaining what to do any least I haven't found it ... Please let me know if you figure it out.
05-28-2017 11:50
05-28-2017 11:50
06-18-2017 09:38
06-18-2017 09:38
i have the same problem please help
@SusanL-2016 wrote:
I have had my new alta 3 days- it is charged and says it is connected and syncing. The display screen is visible when connected to charger but when disconnected the screen is blank. Help!!
06-18-2017 10:31
06-18-2017 10:31
Hey bondo2a
just call Fitbit and they'll replace it! That's what I ended up doing.
06-20-2017 22:46
06-20-2017 22:46
U have year warranty just call fitbit
07-15-2017 06:17 - edited 07-17-2017 04:00
@TanaBanana wrote:
To everyone having a hard time setting up your Alta! There is a small button on the USB part of your charging cord. Push this button 3 times consecutively and then wait a moment. This worked for me after fighting with this thing for 3 days! Hope this helps everyone!
Have the same problem...
I've done this... Several times in fact... It still won't power on.
07-16-2017 20:44
07-16-2017 20:44
07-17-2017 03:51 - edited 07-17-2017 03:58
Good idea cuz nothing is working... How long did it take for you to get your new one?
@michaeljlee3 wrote:Hey bondo2a
07-17-2017 03:51 - edited 07-17-2017 03:57
@gilfish wrote:U have year warranty just call fitbit
Did you get one replaced? If so, how long did it take?
09-30-2017 11:55
09-30-2017 11:55
Thanks for that tip! I just kept pressing the button repeatedly in frustration and the magic 4 digit number finally appeared on the screen... At long last.
10-14-2017 11:44
10-14-2017 11:44
My fit bit will not turn on.
Alto 101
It is charged from plugging into my computer. I set up the App and when I tap it only the little lite circle comes up and nothing else. I do not have the three little lights on the side of the screen
10-14-2017 13:10
10-14-2017 13:10
Hi, @3000000, I am not sure what you mean by the little light circle or the 3 little lights on the side, but you should be aware that your Alta cannot be charged from your computer unless your computer is awake and active. A computer that has gone to "sleep" will not deliver charge -- so the problem may be that your Alta is not actually charged more than a few minutes.
You will need to plug it in to a computer that is AWAKE and ACTIVE for about two hours. Alternatively you can plug it in to a mains electricity charger (such as a cell phone) that will take a USB connection. Please only use a UL/ CE certified charger (the charger supplied with your phone should be fine, but a replacement charger bought on the internet from China could damage your Fitbit).
I hope this helps! Welcome to the forums.
