11-22-2020
15:52
08:01
11-22-2020
15:52
08:01
My alta won't charge to 100% and will only hold the charge for a very short time. I have cleaned the contacts on both the watch and the charger and the app is up to date. Suggestions??
11-22-2020 20:19
11-22-2020 20:19
Hi @SueHW you try restarting your device a few times? It's the first thing to do when there is a problem. You can also check with customer support and they can generally tell you more on their end if the device is charging fully. Also, the Alta HR is older and may have reached the end of life. I have an Alta HR, too.
01-11-2021 05:13
01-11-2021 05:13
Hello @SueHW Welcome to the Community Forums! Thank you for following some troubleshooting steps prior to posting.
@Odyssey13 Thanks for the input! @SueHW for battery not charging, I would like to confirm if you covered all of the steps suggested in our help article: Why isn't my Fitbit device's battery charging?
If your device is able to charge but the battery life is still draining quickly, I recommend taking into consideration the following tips to maximize its battery life: Can I extend my Fitbit device's battery life?
Let me know how it goes.
01-12-2021
12:17
04:38
WilsonFitbit
01-12-2021
12:17
04:38
WilsonFitbit
I have tried many / most of the suggestions and nothing has helped.
Unfortunately my Fitbit has been put on the shelf and I have moved on to
another device.
Moderator edit: removed personal information
Best Answer01-12-2021 13:11
01-12-2021 13:11
@SueHW sorry you've put the Fitbit on the shelf. Please return to edit your post. You have your entire contact information listed - name. employer, phone and email and url. Public forum, so it's not safe to put such private information on there.
Best Answer01-13-2021 04:41
01-13-2021 04:41
Hello @SueHW It's good to see you around! @Odyssey13 Thank you for the suggestion!
@SueHW I’ve created a support case on your behalf. You should receive an email from Customer support. Note that we may take a bit long to get back to you due to recent events affecting our operations.
On a side note, I've edited one of your post that contained personal information.
Have a great day!
