01-12-2021
14:14
09:58
AlejandraFitbit
01-12-2021
14:14
09:58
AlejandraFitbit
My Alta wasn’t syncing to phone. It says it’s synced but not actually transferring data. Deleted device and trying to reinstall. Keeps searching and can’t find device. Have turned Bluetooth off n on again. Bluetooth on phone says it’s connected to Alta but Fitbit app can’t connect them
01-15-2021
09:59
08:27
01-15-2021
09:59
08:27
It's great to see you here, @Leesiepoos.
Thanks for troubleshooting this syncing issue. If you are having problems with the setup process, I recommend taking a look at the help article: Why can't I set up my Fitbit device? and follow the instructions provided there.
Keep me posted.
09:52
08:27
01-17-2021
09:52
08:27
It's great to see you here, @Ladidar.
Since the steps provided didn't work, I've gone ahead and escalated your case to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
In the meantime, let me know if you need anything else.
10:41
08:27
01-20-2021
10:41
08:27
It's great to see you around, @feevilah.
If you are having problems with the setup process, I recommend taking a look at the help article: Why can't I set up my Fitbit device?.
Let me know the outcome.
