09-21-2020 22:21
09-21-2020 22:21
My alta hr is blank since last week all in sudden. I've tried follow your advise to reboot it multiple times, still no display, although it can syncs with my phone app and vibrates when I plug it in. The green flashlight at the back is work just no display.
Please help. Thanks.
01-10-2021 15:49
01-10-2021 15:49
Hi @Emilie606, welcome to the Community Forums!
I’m sorry to hear about this and thanks for the troubleshooting performed before reaching out. The steps to restart your Alta HR can be found in this link How do I restart my Fitbit device?, you can confirm if those were the ones you already followed, if not, you can try them.
I’ll be around if you need help.
Best Answer01-10-2021 16:55
01-10-2021 16:55
Best Answer01-11-2021 11:02
01-11-2021 11:02
Hi @Emilie606, it's great to see you again.
Thanks for trying to solve this. I've gone ahead and contacted our Support team so they can create a case on your behalf and provide you with further assistance. Please note that due to recent events affecting our operations there might be a delay in their reply, but they'll get in touch with you soon.
See you around.
Best Answer01-11-2021 16:57 - edited 01-11-2021 17:00
I’m having the same problem. Yesterday I got a message that my battery was low so I plugged it in. It was dead. No display and I thought it would charge and be fine in the morning but this morning it was dead. I tried pressing the reset button but nothing happened. I cleaned all the connections with alcohol and tried several different outlets in my house but still nothing.the Alta hr tracker is not responding and of course I can’t sync with the app. Please help. Thanks.
-concha
Best Answer01-19-2021 17:21
01-19-2021 17:21
Best Answer01-19-2021 18:30
01-19-2021 18:30
I’m having the same problem. The screen is blank. I could sync it ok but after a few days now the sync doesn’t give me steps or sleep scores. So right now it’s basically useless.
Best Answer01-20-2021 06:12
01-20-2021 06:12
I am also having the same problem - just tried plugging it in and rebooting it but although I know it is charging as it vibrates still no screen 😞
Best Answer01-20-2021 08:20
01-20-2021 08:20
Best Answer01-20-2021 10:39
01-20-2021 10:39
Site can't be reached
