07-24-2020
04:37
17:41
07-24-2020
04:37
17:41
I have read many posts here having the same problems that the Alta does not work after turning off the power charge. Customer servicer advised to restart by clicking 3 times of the buttons blablabla...and this solution failed too. Yeah, I tried many many times! waste.
But, what surprised me most is such big company, instead of finding the way to solve the problem, only suggests its customer buying new device. Yes, I will buy one but NOT Fitbit, again.
Thanks.
Hi. I have not used Alta for a lobg while so it naturally it run out of battery. I have therefore charge it and reset it (several times) but the screen is still black and will not lit unless plagged in. Is not syncronising either.
I'm having the same issue. Mine is brand new. just took it out of the box (Old one I had for 4 yrs had it replaced under warranty once so needed to buy this one) i removed the old Alta and set this one up. It if fully charged and when on the charge will sync with my phone but the minute i take it off it goes blank. nothing shows up and when I go to sync with my phone it states no device found. This is very frustrating. I've removed the device and tried to set it up again but not working.
Yep, I've had my Alta for years. All of a sudden it is blank when it is on my wrist. I keep trying to re-add it. It finds the device, tells me that I'm all set, but nothing. They must've done something with an update!
Best AnswerI just got off the phone with customer service (Fitbit) and they couldn't get it to work either. Since this one is brand new they are sending me a replacement but its taking up to 10 days to get. 😞
Best AnswerDAW56, good for you. What's the number please? Mine is 4 years old but will give it a try. Thank you
