After wearing the device throughout the day, it will continue to show 0 steps and 0 active minutes. I cannot sync the fitbit to my phone until much later but when I do the correct data comes up and the fitbit will display it. Any advice? I need to be able to see my steps/exercise without syncing it.
@Kace1 Please do the below:
restart your Fitbit & restart your phone
below are the instructions on restarting the Alta:
let us know if you need additional guidance or if this was helpful.
@Drmindy Are you able to sync at all?
Sounds like your phone is not syncing properly.
please make sure you have the most updated Fitbit app and your Fitbit is paired to your phone.
If yes, please restart your Fitbit and resync and see if that helps.
Let us know how this goes.
Restarted phone and Alta HR 3x and steps and calories, miles on alta only did not show on phone Android until 4th restart. Sleep data is showing basic only. Are you pulling an apple move and making are devices obsolete?
Works now!
Thank you
Works now!
Thank you for your help
