Alta won't stop vibrating
My Alta started buzzing non-stop for about 5 minutes and stopped when I plugged it in. It showed the Alta logo and the version and turned off. It will not sync with my phone and the screen will not turn on. I restarted it and it showed the low battery symbol so I left it to charge over night and when i checked it it wouldn’t work. I tried restarting it several times but it still won’t work.
1 REPLY 1
It's great to see you around, @Suzie13.
Thanks for troubleshooting this vibration issue. Upon checking with our support team, I was told that you have already contacted them. I know they will be glad to help you out and provide you a solution, just keep an eye on your inbox for further assistance.
In the meantime, let me know if you need anything else.
