02-19-2021 02:13
02-19-2021 02:13
Hey Community,
after reset my alta i see the fitibit logo and the newest version on the display. After unplugged the display goes to "sleep mode" and wont go on again till i plug it in.
The phone connection works and other infos on the Display can be switched.
If its plugged again the battery level is on 70 percent.
I havent used it for two years. But its strange for me that the battery level is displayed.
Is the battery broken?
02-20-2021 01:11
                              02-20-2021 01:11
Hi @Prafessor Lithium Ion batteries hate being left flat for long periods, so it is likely the battery has given up. U fortunately there is probably nothing you can do. Sorry.
Helen | Western Australia
