01-02-2020
08:26
17:50
01-02-2020
08:26
17:50
I have just started using my Alta again. Been unused for 3 months. Cannot get it to sync. Have looked at manual and followed instructions to restart but I have no button on my charger to press 3 times. Can anyone advise another way to restart my device. Wont synch on Android app or Windows 10 laptop. Have unistalled and re installed app too.
Hi @goldengoose unfortunately you need the authentic Fitbit charger to restart your Alta. Some third party sellers have been putting charging units on the market that don't have that little button, so people can't restart their devices. There is no other way to restart your Alta. You can buy from the Fitbit Store online or you can check with local retailers (Best Buy, Walmart, etc) to see if they have the charger you need.
Best AnswerHi @goldengoose unfortunately you need the authentic Fitbit charger to restart your Alta. Some third party sellers have been putting charging units on the market that don't have that little button, so people can't restart their devices. There is no other way to restart your Alta. You can buy from the Fitbit Store online or you can check with local retailers (Best Buy, Walmart, etc) to see if they have the charger you need.
Best AnswerThanks very much. Yes, I stood on my charger and bought one off Amazon. I am based in UK but will look for authentic charger. Sx
My fitbit synced for the last time on December 20th. Checked the manual, went online and followed all instructions to get it up and running with no luck. Finally contacted customer support last week and after about an hour on the phone with them, was told that my phone was no longer supported by the fitbit app. Not only am I totally disgusted with fitbit, that they would do this, but also, that no one notified me that this was going to happen. I have a Samsung S5 which operates perfectly in every way, so I see no need to get a new phone. As I told the fitbit agent, my choices are to either get a new phone or quit using my fitbit. You can be certain that the fitbit will be the one to go. My fitbit is now just a piece of junk. I hope others see this and realize that the same can happen to them when fitbit decides to quit supporting their phone.
Best AnswerWould it sync with a new or different charger? Customer service agent just told me that my phone (nothing to do with the charger) is just no longer supported by the fitbit app.
Best AnswerHi @EllieO your charger doesn't sync. Getting another charger unit won't help if you can't sync. The charger is just for charging.
Best AnswerI realize that a new charger will not help. Which is what makes me especially angry that Fitbit just randomly decided to no longer support my phone. As I said in my previous comment, the Fitbit watch is now just a piece of junk.
Best Answer@EllieO my Samsung S4 still works, not all the features, but enough to be able to use it. My S4 is not on the list of compatible devices click to see
Best AnswerThis post from Moderator @SilviaFitbit explains it quite nicely - click to read
