01-06-2019
05:45
18:17
01-06-2019
05:45
18:17
I have an Alta (not HR). This time when I charged it, whenever I tap, rather than the clock showing, the battery symbol is shown first. I synced it & the battery shows fully charged. Anyone know how to correct this? Thanks!
01-09-2019 19:34
01-09-2019 19:34
I put my Alta on the charger today. It seems to have reset itself. The clock is coming up like it’s supposed to now.
Best Answer01-06-2019 05:54
01-06-2019 05:54
I will move this to the Alta forum.
In your app, go to your Alta (tap on the tracker icon in the top right corner) and scroll down to Customise Display. There you can change the oder of the screens you see.
Helen | Western Australia
01-06-2019 10:43
01-06-2019 10:43
01-08-2019 15:36
01-08-2019 15:36
I’m having the same issue.
01-08-2019 17:31
01-08-2019 17:31
I have the same issue. I’ve actually unchecked the box for the battery, so it shouldn’t be showing at all 🤔
Best Answer01-09-2019 19:34
01-09-2019 19:34
Best Answer01-10-2019 05:37
01-10-2019 05:37
Best Answer01-10-2019 10:01
01-10-2019 10:01
I have the same issue .. first tap or twist of wrist shows battery level instead of time.
Best Answer01-29-2019 13:36
01-29-2019 13:36
Thanks I will try this
Best Answer05-21-2019 18:44
05-21-2019 18:44
I am having the same problem. I have: 1-changed the order of what icon to show have battery in the middle then charged
2- turned if battery and charged
3- synced and charged
I have done all the steps requested yet no results.
in top of all that when This problem started my text messages no longer appeared on my Fitbit
07-04-2020 05:40
07-04-2020 05:40
I’m experiencing the same issue. In the settings, the battery is completely unchecked... did you ever find a solution to this?
Best Answer07-07-2020 07:39
07-07-2020 07:39
