12-18-2020 06:53
12-18-2020 06:53
Is there a way to have the bracelet show the battery level without having to find it on the app?
12-19-2020 00:06
12-19-2020 00:06
I noticed this in the manual:
"If your battery is low, when you wake up your Alta HR you’ll see low battery icon
after a few seconds. If you see a critical battery icon you’ll be unable to flip through
your stats until you charge your tracker. Your tracker continues to track your
activity until your battery runs out. Note that heart rate tracking will stop when
your battery level is at approximately 5%.
You can check your battery level at any time on the battery screen on your tracker
or on your Fitbit dashboard. You must turn on the battery screen in the Fitbit app, it
is not on your tracker by default. "
Could it be that you have yet to turn on the battery screen?
12-19-2020 03:51
12-19-2020 03:51
01-06-2021 07:59
01-06-2021 07:59
Hello @Cjones1764 Welcome to the Community Forums!. Thanks for the input @SteveH.
I was able to see here that our friend @SteveH provided some instructions. Was this the answer you were looking for? If it was, I recommend marking the answer given as the best answer. By doing this, other users with the same inquiry will be able to find a faster response.
Have a great day!.
