12-24-2019
12:59
20:01
12-24-2019
12:59
20:01
Does anyone know if I can calibrate my fit bit? It seems to be counting steps when I am sitting or driving.. 😞
Hello and welcome to the Fitbit Community @Kathleenkus
You might experience “steps” while sitting or driving because of arm movements and on bumpy roads or in a car with a stiff transmission, your device may add some steps. For most individuals, the number of extra steps added when driving isn’t significant when compared to your overall stats. If you want to remove the steps from your daily total, manually log the driving activity for the time you were in a vehicle. For more information see How do I edit or delete Fitbit data and activities?
But if you feel that is not the case you can try restarting your Alta (Alta HR) to see if that improves your issue.
Here’s how:
😃 Please let me know if this answers your question. Keep me posted
Best AnswerHello again @Kathleenkus
I wanted to check back in with you to see if my suggestions did indeed answer your question. 😃 Please let me know
