04-12-2020
05:30
21:32
EstuardoFitbit
04-12-2020
05:30
21:32
EstuardoFitbit
I got a fitbit yesterday and just discovered I need to use my non-dominant right hand.. I'm a leftie.. How do I do that on the app? Thanks
Yea they purchased it new, but they aren’t sure they kept the docket, they are going to search for me so fingers crossed otherwise bummer I guess if it’s defective there will be nothing I can try 😔
😔 they no longer have the receipt
is there a way I can contact Fitbit ? I’m in Australia if that makes any difference
Best AnswerThe link to Contact Fitbit may be found in the top right slide out menu.
Not knowing the history, is it possible the tracker sat with a dead battery for a few months/years?
