04-13-2020
21:24
21:31
EstuardoFitbit
04-13-2020
21:24
21:31
EstuardoFitbit
Whenever I submit a custom food the calorie value shows as 0. I’ve made sure to double check that I’ve entered the calories before pressing submit and it still shows as 0. This is a problem because more often than not, when I scan the barcode of most products the nutritional information is incorrect.
Is this a glitch?
04-13-2020 22:14
04-13-2020 22:14
Have to wait for IOS app 3.19 to correct this known issue.
Best Answer04-13-2020 22:44
04-13-2020 22:44
I don’t know what that means.
Best Answer04-14-2020 08:27
04-14-2020 08:27
@Bluefield wrote:I don’t know what that means.
It means it will be corrected in the next IOS app version 3.19.
Sorry if that doesn't make sense. I don't know how else to explain it.
Best Answer04-15-2020 16:19
04-15-2020 16:19
That’s OK. I’m a little slow. It’s the latest update to the software.👍🏼
Best Answer04-15-2020 16:34
04-15-2020 16:34
But you should be able to enter them on a computer fitbit.com
Best Answer04-15-2020 16:35
04-15-2020 16:35
Oh, that’s good to know. Thank you!
