01-10-2021 12:59
01-10-2021 12:59
Cant find my dashboard on my android only just got the fitbit
01-10-2021 13:07
01-10-2021 13:07
Hi @Irish32,
Welcome aboard! You need to download the Fitbit app on the Google Play store and log into your account. The page that you see next with all your stats is your Dashboard.
one cruise ship at a time!
Best Answer01-10-2021 13:17
01-10-2021 13:17
I have done that and it came up but how do I get it up again
Best Answer01-10-2021 16:31
01-10-2021 16:31
Hi @Irish32, can you tell me (or better yet, send in a screenshot) of what you see on your screen? Then can you tell me exactly what you're trying to view? Without that information, I can't be of more assistance.
Best Answer01-10-2021 17:45
01-10-2021 17:45
I dont know how to send a pic on here
Best Answer01-11-2021 15:22 - edited 01-11-2021 16:44
Hi @Irish32, when you hit the "Reply" button to this message, you should see a small camera on the right hand side of your screen, next to a smiley face. That's the camera you want, please click on it. From there, you can upload the photos directly from your computer.
I got called away for a second, sorry about that. To take the screenshot, there's two ways you can do it:
1.) On your phone, you can usually press a side button and the volume down button at the same time. Each phone model may be slightly different, but on my Moto e5 Play, you can press the volume down and the power button at the same time. From there, it will save to wherever your phone saves pictures (usually under "Camera Roll" or in my case. "Google Photos"). Next, [lug the phone into your computer and download the images (each model has their own process for doing this, so you will have to refer to your cell phone maker's instructions for this part). Finally, save the images to your computer and then upload the images to the Fitbit site using the aforementioned instructions.
2.) On the computer, a lot of them have a program called "Snipping Tool". You can usually find this in the main menu of your computer, Open the Fitbit app and the Snipping Tool. Select "Create New Snip" and then go over to the Fitbit app. Right click and drag over the area you want to "snip". Once you've selected everything you want, right click on the area you selected and select "Copy". Then go back to the Snipping Tool, right click and select "Paste". From there, you can save the image to your computer and upload it to the Fitbit site using the aforementioned instructions.
