01-11-2020
05:48
20:01
01-11-2020
05:48
20:01
In my sleep pattern the graph lines are vertical not horizontal across the screen. Looks like it went back to an older version.
01-12-2020
13:12
06:34
01-12-2020
13:12
06:34
Hi @dclark7, It's nice to see you again participating here in the Community Forums, welcome back!
Thanks for bringing this to my attention. If you're receiving vertical lines on your sleep graph is because your device didn't recorded Sleep Stages but auto-sleep logs which are simplified. That said,
there are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of Sleep Stages, which are the following:
Let me know if you require further assistance.
Best Answer01-12-2020 16:39
01-12-2020 16:39
16:22
06:33
01-14-2020
16:22
06:33
Your update is appreciated @dclark7, my apologies for the delayed reply.
Thanks for taking into consideration the steps that were shared on my previous post To move forward with this, can you please let me know if you continue experiencing difficulties with the Sleep Stages tracking?
Looking forward to your reply.
Best Answer01-14-2020 17:29
01-14-2020 17:29
01-16-2020 17:37
01-16-2020 17:37
My device does not show sleep stages when using the automatic monitoring at night. Although it says that using the sleep now button will give you the simplified information, I need to use the sleep now button to get the detailed sleep stages. My device must be wired backwards:)
19:45
06:32
01-19-2020
19:45
06:32
Your update is appreciated @dclark7. Welcome aboard @Nibbles1. Sorry for the delay in responding your posts.
@dclark7 I'm really happy to know that your issue was resolved. Please do not hesitate to contact me back if you require further assistance or if you have any additional questions for me to answer.
@Nibbles1 Seems odd that you need to use the Sleep Now button in order to receive Sleep Stages. When you don't use such feature, do you receive any error message explaining you the reason why you didn't receive Sleep Stages?
I'll be around.
Best Answer01-19-2020 20:56
01-19-2020 20:56
When I don't use the "sleep now" button I get inconsistent tracking. I sleep for about 5 hours but it only records for less than 3 hours (which it will tell me it needs more than 3 hours to track). No error messages pop up..
