12-29-2019
07:47
17:50
12-29-2019
07:47
17:50
Got a new Alta for Christmas and it will not work unless connected to a charger. Tried deleting app 2x as well as "forgetting" device 2x and starting it over again.
Any help or guidance? Thinking we may have a dud. 😞
12-30-2019
14:03
07:30
12-30-2019
14:03
07:30
Hi @LisaGff, welcome to the Community Forums!
Thanks for bringing this to my attention and for troubleshooting your device prior to posting too. If you haven't already done so, I recommend you to check our help article: Why isn't my battery charging on my Fitbit device? and let me know how it goes. Such article includes a restart process which can be really helpful for this situation
Let me know if you have any additional questions, I'll be here.
16:25
07:30
01-14-2020
16:25
07:30
Your update is appreciated @LisaGff, my apologies for the delayed reply.
Thanks for the information that was shared with me. To move forward with this and for a better understanding of the issue you're experiencing, can you please let me know if after unplugging your Alta from the charging cable your device becomes unresponsive or you are unable to sync it? If your device isn't tracking steps, the restart process that was shared before should rectify this situation.
In regards the syncing difficulties, can you please let me know which mobile device are you using? I recommend you to check how the syncing procedure works here and see if there's a missing requirement on your mobile device that's preventing the syncing procedure to be completed. Also, you can move forward to the troubleshooting steps that are specified on: Why won't my Fitbit device sync? and let me know how it goes.
Keep me posted.
