12-24-2018
18:31
18:17
12-24-2018
18:31
18:17
Alta screen loses display even though it is fully charged. I get error code V21 40.02 briefly when I put it on the charger.
12-24-2018 19:57
12-24-2018 19:57
That is not an error code. That is showing which version your tracker is on, though I realize that doesn't address your losing the display.
Best Answer06-03-2019 02:00
06-03-2019 02:00
I bought a new fitbit in Dec 18 because of this issue with my old one (which was 2 years old). Now on my fourth replacement from them, all have the same issue. Not sure there's a solution other than to give up with it
Best Answer06-03-2019 08:31
06-03-2019 08:31
Was your issue that the display would not activate? I didn't bother trying to get a replacement but I did purchase a new one in February 2019. Maybe I should still try to get Fit BIT to replace my original one - did you try that - or did you just purchase all your replacement units?
06-03-2019 09:54
06-03-2019 09:54
Yes it was charged but when I took it off at night it never came back on next day even though almost full battery. As I said the replacements they keep sending me have all had the same problem but worth a try - you might be luckier!
02-16-2020 06:48
02-16-2020 06:48
Same issue here. The only way I could ‘wake it up’ was to plug it in quick. 😞
Best Answer05-27-2020 07:26
05-27-2020 07:26
Exact same issue …. it only works once I plug it in ...and then it just randomly turns off again 😞
05-27-2020 11:17
05-27-2020 11:17
Best Answer06-18-2020 12:16
06-18-2020 12:16
I have had my fitbit for over 5 years and it has just started doing the same thing, usually just once every so often but it's been at least 5 times today!! I am assuming from messages here there is no way to resolve this issue?
06-18-2020 12:23
06-18-2020 12:23
Best Answer06-18-2020 12:33
06-18-2020 12:33
